Edge IO is now available to customers
Tulip is replacing its flagship I/O Gateway device with the new Edge IO, a wifi-enabled, easy-to-implement, low-cost edge device for collecting operational data and integrating it directly into the Tulip platform.
Edge IO
Connect machines, devices, PLCs, and sensors with Industrial I/O ports, and USB connectivity.
Edge IO natively supports powerful high-speed current and vibration measurement. Combined with external off-the-shelf sensors, Edge IO can monitor stranded and proprietary machines in the cloud. Networked machines can be connected with Tulip’s OPC UA support, and Node-RED onboard the device.
Edge IO can run Tulip apps directly with an external touchscreen monitor and run as a complete workstation. The addition of 2 integrated Tulip Light Kit channels further reduces the need for additional hardware, making it easier than ever to get started.
To learn more or purchase an Edge IO visit the Tulip website or contact a Tulip team member.
To get started using an Edge IO, visit the Knowledge Base.
Edge IO will be widely available on February 17th, 2022, at a cost of $600
Factory Kit
The Tulip Factory Kit is being updated with Edge IO included. Light Kit is being replaced in the Factory Kit, and two Light Strips will be included instead. Edge IO natively supports 2 Light Strips.
The USB Light Kit device will continue to be sold and supported on I/O Gateway and Edge MC.
To learn more or purchase a Factory Kit visit the Tulip website or contact a Tulip team member.
Factory Kit with Edge IO will be widely available on February 17th, 2022
@jemmadupuis and @kcamenzind what are some recommended vibration sensors to use with the Edge IO?
The sensor we currently recommend is:
IEPE Accelerometer, MFG: PCB Piezotronics, P/N: 603C01
It can be purchased from the manufacturer.
To learn more about the recommended sensors for Edge IO, check out this support article.
@jemmadupuis , thank you very much!
How many USB ports and what power output for each?
Thanks for your question @jmlowden - there are 6xUSB 2.0, which are specified at 500mA @ 5V (2.5W).
You can find the technical specs here: Edge IO Technical Specifications
Hope that helps!
I currently use an Edge IO to connect Tulip to a printer.
I would like to connect it to a second printer, do I have to buy a new Edge IO or can it be connected to two machines?
@sami.janati It depends on the method of connection you are using for your printer. The Edge IO has many type of connection ports as detailed in the spec link above - so as long as there is another port to hook up to, you should be good to go to hook it up to multiple devices!
Another consideration is that depending on the device, you can connect it to Tulip multiple ways, (for example Zebra printers (Update Tulip Device Library Printers Page - #4 by k.ober) so there are also options there
