Hi everyone,
I am trying to connect a Datalogic TC1200 industrial barcode scanner to the embedded Node-RED instance on my Edge IO.
I want to process the raw serial data inside Node-RED before routing it, so I cannot use the native Tulip Barcode driver for this specific use case.
My Setup & Steps Taken:
Scanner Configuration: Configured the TC1200 via Datalogic Aladdin into USB-COM Standard mode (Virtual COM Port). I verified it on a Windows PC; it is correctly recognized as a USB Serial Device (COM Port) and no longer acts as a keyboard.
Edge IO Drivers: Turned OFF both the Barcode and Generic Serial drivers in the Edge IO Device Portal to avoid any conflict or port capturing by Tulip’s native OS.
Reboot: Performed a full hard reboot of the Edge IO with the scanner connected.
The Problem:
Inside Node-RED, the serial in node fails to open the port and throws the following error: [serialconfig:xxxx] serial port /dev/ttyACM0 error: Error: Error: Permission denied, cannot open /dev/ttyACM0
Diagnostics via Node-RED exec node:
I ran a few commands within Node-RED to check what is happening under the hood.
lsusbsuccessfully detects the device:
Bash
Bus 006 Device 004: ID 05f9:2206 PSC Scanning, Inc.
ls /dev/tty*confirms that the port/dev/ttyACM0is created by the OS. -
However, checking the permissions with
ls -l /dev/ttyACM0 && whoami && groupsreturns this:
Plaintext
c--------- 0 nobody nogroup 166, 0 Jun 1 14:54 /dev/ttyACM0
node-red
nogroup node-red nogroup
Questions:
As we can see, /dev/ttyACM0 is created with 000 permissions and owned by nobody:nogroup, which prevents the node-red user container from accessing it. Since the node-red user doesn’t have root/sudo privileges inside the container, I cannot manually chmod or chown the device path.
Is this a known restriction regarding how USB-serial devices are mapped into the Node-RED Docker container on the Edge IO?
Is there a way to trigger a
udevrule or configure the Edge OS so that dynamically plugged USB-serial devices are created with the correct group permissions (e.g.,dialout) or read/write access for Node-RED?
Any insights or workarounds from the Tulip team or community would be greatly appreciated!
Paul
