I am a new Tulip user and I just exported completions from my first App. I can see Duration as a field in my completions, but the Duration field is not included in my exported data. I can recreate Duration using Start Time and End Time, but I don’t want to go to the extra effort when the field exists. Has anyone else had this problem? Suggestions?
Hey @velogirlrides ,
Welcome to Tulip Community
If you choose the export option: Print Current Page As PDF, you will be able to see the Duration field in the Report:
Like you’ve seen, the Duration field doesn’t populate in the csv export. One thought could be to add a trigger like this, and save the duration as a Variable, which would be included in your Completion Data:
Hopefully that helps, let me know if you any follow up questions!
