when publishing a new version I 'm getting the message that there is one disabled trigger in 1 step:
But where? I have dozens of steps and triggers.
Pls give more information about disabled trigger and where to find.
Chris
Chris
Hey @ChrisF
I will write up a feature request to make it more clear which step/widget has the disabled trigger. Thankfully it’s pretty easy to see what trigger is disabled.
By default each trigger is enabled (see below) but triggers can be toggled off for testing. Flipping through your steps should make it fairly quick to see the disabled trigger. Important to note - you can still publish an app with disabled triggers, this is just a warning. If its on a widget, it could be a little tricker to find (which is why I think we need a feature request for this).
Hope this helps,
Hey @ChrisF -
A step in the right direction was recently released. Now step name is listed for each disabled trigger:
This is in prep to eventually provide links to find these triggers directly, but a step in the right direction.
Thanks for this request - It was the trigger for this change. Keep the ideas coming
