Fluke 28x driver with Fluke 287 Multimeter
I’m having trouble seeing output data from my Fluke 287 multimeter in Tulip. I was told the Fluke 287 was compatible with this driver. For some reason the device output is not being triggered. Am I missing something?
-Meter is connected to Edge IO USB port 4.
-Driver is enabled on said Edge IO.
-Trigger in app is set to show data when device outputs from the Edge IO
-I’ve tried running the Tulip Player and test station on my instance
-I’ve tested the Fluke meter on my PC using Putty for serial communication and that worked fine
Hi Julia,
I know you came to Office Hours this morning regarding this question and were directed to Tulip Support for further assistance. I went ahead and made a ticket for you already, so you should see that in your email inbox!
Yes I just received the ticket # via email. Thank you!
Just following up here for anyone else who sees this post / could have encountered a similar error - there was a bug in the Fluke driver that was patched and resolved this issue.
