Tulip Multimeter
Hi Guys,
Any one has ever tried to connect a connected multimeter to a Tulip Gateway? If yes, can you if it’s simple or complicated and if it’s possible to give me the reference of this multimeter?
thank you,
Hey @FahdERM ,
With an I/O Gateway you’ll be able to connect to a Fluke 28x Multimeter. You can find the spec sheet here. I believe the set-up is rather straight forward.
Kailey
