Hello, I am looking to add a Brecknell scale to my Gateway and I need to know if you can tell me the baud rate, byte format, and the protocol you use to communicate to Tulip? it recognizes the scale is hooked up but I can’t get the readings from the scale into Tulip.
You should try to hook up this scale using the existing Brecknell PS25 driver. Then, create a trigger around the Brecknell PS25 output in an app. If this does not work, then we will not be able to connect to that particular scale.
For an updated list of devices that can work with Tulip, check out tulip.co/devices.
