Brecknell Scale
Hello guys,
Can i use a PS25 Brecknell Scale directly with Tulip without using a Tulip Gateway?
Thank you,
Fahd, Tulip Gateways are the main interface point between the Tulip platform and our supported hardware. You can do some pretty awesome stuff without a gateway, but for the PS25 you will need one!
Spencer
Thank you for your help. Another thing please, can you list hardware that are supported buy the gateway and can be, at the same time, used without the gateway.
thank you,
Hi Fahd,
Thanks for your question. Most devices require a gateway connection. However, there are a couple that can be used without. Devices that can output as a keyboard will work well simply plugged into your laptop. Nearly all bar code scanners can do this. Currently, other devices will need a gateway connection to be used with triggers. Does this help?
Brian
Hello,
Could you inform me if there is a list with all the devices/hardware that the gateway supports?
It is important to know in case I need to buy a device if the gateway will suppot it.
And more important if I will be able to find this device in another country.
Cheers
hello @Oshiro, you can find the list of supported devices by the gateway here: https://tulip.co/devices/.
specifically, here are the scales: https://tulip.co/devices/#measurements-weight.
is this what you’re looking for??
gio
I just need to know what devices the gateway supports.
I am about to beggin a new project and I would like to know If a gateway would satisfy all my needs, or if I can make this project run without it.
Thanks
@Oshiro those are the Gateway supported devices.
currently, only Barcode Scanners from that list do not require Gateways and can be plugged directly into computers or tablets.
Ok.
The Barcode scanners can also read QR CODE?
Thanks, one more thing, since I am located in Brazil, does TULIP suports any other zebra printers, or only from GK SERIES ?
it depends on the barcode scanner, it needs to have 2D scanning capabilities.
yes, only GK series.
hope this helps!!
Helped a lot!
Just one more thing, if I already have a zebra printer on a desktop, is there any way I can print the label using the printer I already own?
maybe withou the gateway?
great to hear @Oshiro!!
yes, if it’s a GK printer you can use it with Tulip!!
the integration with this specific device does require a Gateway
Tulip driver works also with ZT Series in our configuration
I found a software where it can submit a print label’s request.
Could I use it to print a QR code generated in TULIP? Even not being a GK or ZT series?
Another question,
If I have a Desktop with a zebra printer with a driver on it to comunicate with the cloud, can I print the QR CODE that way?
thanks for sharing @Oshiro!!
what type of printer are you referring to?? if it’s connected to your network, you can print apps using the Print Steps action: How Operators Can Print App Data Or Save it to a PDF
I was not aware @youri.regnaud, thanks for sharing!!
It would be a Zebra printer.
But since I am in brazil, the GK series are not standart here.
That’s why I am asking so many questions about printing a qr CODE label.
ahh OK, I think there’s been a slight misunderstanding here!! the GK Series is a model of the Zebra printer @Oshiro: https://www.zebra.com/us/en/products/printers/desktop.html#mainpar-productseries_74b9.
do you know which model Zebra printer you have?? (as @youri.regnaud there are other Zebra printer models that work with Tulip - although they do all require a Gateway).
We use ZT230 Zebra Printer connected to Tulip through Gateway
But if I use the Nice label software (https://www.nicelabel.com/label-cloud), can I use it to print a QR code from others zebra printers that are already installed on a desktop?
