I’m trying to make a custom widget that would generate a CSV File. It seems I’m reaching a dead end on getting the widget to work. Is there a proper process to do this?
I’m planning to store the generated CSV files into table records.
Hi Anthony!
Welcome to Tulip Community ![]()
Where have you gotten stuck / do you have any errors you can share to help the Tulip Community further debug this?
Hi @sasa
tldr.
