Get working hours between two dates and times
If I have two dates can I get the working hours between them through the Expression editor (considering that I know that the working hours are 8-4 pm on weekdays?
I.e. Date1: Sat 22-Sep-2022 9:00 PM and Date2: Mon 24-Sep-2022 10:00 AM → Result should be 2h
Hey @DariusM -
This is super tricky to achieve with normal trigger logic for a bunch of specific edge cases, its possible (I think, but it would be super clunky) to handle cases like if the end date is in a different year than the start date (and a whole bunch more).
Because of this I went down the custom widget road to achieve this functionality. Even in Javascript, supporting all the potential edgecases correctly was a bit of a challenge (and there may be additional cases that I missed, but its close).
Setup:
Check out this doc on how to import a custom widget:
This widget has 5 inputs. Start time, End time, Exclude weekends, shift start time and shift end time. in your case I would set these as follows:
  • Start time - Whatever variable you are using to track the starting point of the range you want to measure
  • End time - Same deal as start time, just the other end of the range
  • Exclude weekends = True
  • Shift start time = 8
  • Shift end time = 16
There may be edge cases I didn’t catch in my testing, feel free to iterate on this guy if you find any!
customWidget-Get Hours Between Dates (1).json (6.7 KB)
Note: This widget didn’t go through our standard code review process. Use it with caution
Hi @Pete_Hartnett ,
I tried to import your custom Widget into my instance but got this error message :
Do you know what could be the issue ?
Paul
My be easier to try and solve this using a Postgres SQL Connector. You can see an example of the postgres function here:
And here is an example of someone using the default postgres connector to access postgres functions from Tulip:
For posterity, here is how I did this with the CW:
HTML
<button id='btn'>Calclulate</button>
JavaScript:
$('#btn').click(function() {calculateDelta();})
function getDate(dt_obj){
    //Convert a Tulip Datetime to a JS date object
    let d = new Date(0); // The 0 there is the key, which sets the date to the epoch
    d.setUTCSeconds(dt_obj['timestamp']/1000);
    return d
function getShiftStart(start){
    //Get the datetime of the shift start, on the date of the starttime.
    //So if starttime is 1/1/2022 at 13:00 and shift start time is 8
    // this would return 1/1/2022 at 8:00
    const startOfDay = new Date(start);
    startOfDay.setHours(getValue("Shift Start Time")||0);
    return startOfDay
function getShiftEnd(end){
    //Get the datetime of the shift end, on the date of the endtime.
    //So if endtime is 1/1/2022 at 13:00 and shift end time is 16
    // this would return 1/1/2022 at 16:00
    const startOfDay = new Date(end);
    startOfDay.setHours(getValue("Shift End Time")||24);
    return startOfDay
function getBusinessDatesCount(startDate, endDate) {
    //Returns the number of business days between 2 dates
    console.log(startDate.toLocaleString(),endDate.toLocaleString());
    let count = 0;
    let first = true;
    const curDate = new Date(startDate.getTime());
    while (curDate <= endDate) {
        const dayOfWeek = curDate.getDay();
        if(dayOfWeek !== 0 && dayOfWeek !== 6){
            count++;
        curDate.setDate(curDate.getDate() + 1);
    //alert(count);
    return count;
function getDaysCount(start,end){
    //Returns all the days between 2 dates.
    let Difference_In_Time = end.getTime() - start.getTime();
    let Difference_In_Days = Difference_In_Time / (1000 * 3600 * 24);
    return Math.ceil(Difference_In_Days)
function getTruncDateTime(date){
    //Returns the time being passed in, but truncated to 00:00 on that day
    let startOfDay = new Date(date);
    startOfDay.setHours(0);
    //console.log("Before return test", startOfDay.toLocaleString());
    return startOfDay
function betterDeltaEnd(measure,shiftEnd,shiftLengh){
    let shiftStart = getShiftStart(shiftEnd);
    if (measure.getTime()<shiftStart.getTime()){
        console.log("in 1")
        return shiftLengh
    else if (measure.getTime()>shiftEnd.getTime()){
        console.log("in 2")
        return 0
    else{
        console.log("in 3")
        let diff = shiftEnd.getTime() - measure.getTime();
        diff = diff/1000/3600
        diff = Math.floor(diff)
        return (diff)
function betterDeltaStart(measure,shiftStart,shiftLengh){
    let shiftEnd = getShiftEnd(shiftStart);
    //console.log(shiftEnd.toLocaleString());
        //console.log("in 1")
        return shiftLengh
    else if (measure.getTime()<shiftStart.getTime()){
        //console.log("in 2")
        return 0
    else{
        let diff =measure.getTime()-shiftStart.getTime();
        //console.log("in 3")
        return (diff)
function calculateDelta(){
    let ST = getDate(getValue("Start Time"));
    let ET = getDate(getValue("End Time"));
    let trunc_ST = getTruncDateTime(ST)
    let trunc_ET = getTruncDateTime(ET)
    let shift_start =  getShiftStart(ST);
    let shift_end = getShiftEnd(ET);
    let hours_in_day = getValue("Shift End Time")- getValue("Shift Start Time")
    // if it is currently after the start time, return by how much
    let startAlreadyElapsed = betterDeltaStart(ST,shift_start,hours_in_day);
    //if it is before the end time, return that time
    let endNotElapsed = betterDeltaEnd(ET,shift_end,hours_in_day);
    //console.log(endNotElapsed);
    let allDays = getDaysCount(ST,ET);
    let businessDays = getBusinessDatesCount(ST,ET);
    let days = null
    let final_hours = null;
    if (getValue("Exclude Weekends")){
        days =businessDays;
    else{
        days = allDays;
    let fullDayHours = days * hours_in_day;
    let finalVal =fullDayHours - startAlreadyElapsed;
    finalVal -= endNotElapsed;
    console.log(allDays,businessDays,fullDayHours,startAlreadyElapsed,endNotElapsed,finalVal);
    fireEvent("Hours",finalVal);
CSS:
body {
	background-color: transparent;
	font-family: Sans-Serif;
	font-size: 40px;
	padding: 10px;
button {
	background-color: #3A89EB;
	border-radius: 4px;
	border-width: 0;
	color: #fff;
	cursor: pointer;
	font-size: 24px;
	padding: 16px;
button:active {
	background-color: rgb(3, 106, 214);
