When I attempt to edit the background color value of a cell within a grid widget, I’ve found several issues.
When I click into the Hex color text box and begin typing the color I’d like, it instead starts adding the text into the grid cell itself. If I click the hex color entry box again, it will allow me to type the value, however the color will not apply. The only way I can find to actually apply the color to the grid cell is to click / drag to the precise color that I want.
Additionally, if I click a grid that already has a color set and attempt to view its background color to grab the color value, the correct color value does not display, instead always defaulting to #22194D.
I appear to be having a similar issue with editing grid cell text color.
