Headless Change Detector
Good morning,
i dont have time to write long dokus. But i will post short overviews of my testcases.
So here is the first one. The headless change detector. It provides Trigger-Events on variables.
ChangeDetector
Thanks @nils.husemann … a picture tells a 1000 words. Also you can export and upload your widget if you are happy to share with others. Instructions are here
@nils.husemann I have gone back and forth on if the event should fire every time a key is pressed, or just when the user leaved the field for number and text inputs. (“input” vs “change” in the event listener). I could see a user wanting to auto advance after a user types in a whole order number, and if it fires every key they would need to run a regex in the event trigger.
Curious of your thoughts about this-
@nils.husemann I knew this feature in your hands would be like adding mentos to coca cola (or some other analogy that means nils + this feature = awesome things happen). So exciting to watch you build!
I’m also very interested in what @mellerbeck conjures up…
Thanks for sharing!
