Allow for text\numeric input widgets to have trigger logic when "input changes"
Hello!
Interested to hear if a possible update can be made to text and numeric entry widgets to allow for a trigger timing of “input changes” (similar to date time entry widget).
There are several use cases for this, most notably performing calculations when a value is entered. The “when enter key is pressed” timing forces extra button presses\clicks that are not inherently intuitive to operators\manufacturing personal - as these entries are the only ones that require them to perform trigger logic.
I did see other user posts like this one, with the suggested custom widget work around:
However, my use case in life-science is very restrictive in the use of custom widgets.
Thanks!
Brendan
Hi @bklempa, thanks for your post! We are actively working on this enhancement. I hope to reach back out soon with an update! :slight_smile:
Hi @shep, appreciate the response! Looking forward to the update.
Great news! This has been included in Platform Release 306 - February 2025 :tada:
