Exciting news - Release 306 is here!
Share your thoughts and questions below
How write attributes are link to MQTT write function? I miss something?
Hey @youri.regnaud,
Before this release, we could only ingest MQTT data through machines, and write to it from connectors - this work was to allow you to go bidirectional directly through machines if you are not working with complex payloads (or if you are working with OPC UA).
With this release, you can utilise at this station trigger mapping to build apps that can be more easily leveraged across stations.
If you are working with complex business objects, like in a UNS use case, you can still write to these complex objects through connectors.
Wow… some big bangers seem to enter the room ![]()
Some great things included in this release from Tulip Community!! ![]()
Testing mode connector environment label has been updated to match the rest of the product.
With the new when “input is exited” condition option for triggers of text, multiline, and number input widgets, the following requests are resolved!
Last but not lease, conditional formatting on interactive tables is here!!
Thanks all for the great input and let us know how you like these new features ![]()
Thank you for the implementation of conditional formatting👏
I have seen in the release notes that this function is being further developed. It would be very helpful if the comparison of values from 2 different columns of the interactive table could also be implemented, e.g. to be able to compare target and current quantity or shipping date and completion date.
I love the conditional formatting. I already use it an a new App and it helps a lot.
I really appreciate this feature!
However, here are my challenges, I had to work around or had to discard (for now):
I want to format based on a column, that is not displayed (as possible in sorting and filtering).
I want to compare a column value with another column value
I would love to have a select all button to select all columns (“Apply to” section)
I’m missing an is in and is not in condition (as available on filters)
Hey everyone @jjj, @pwied, @thorsten.lagner!
@jjj, Regarding conditional formatting for Table Analysis, this is actively under consideration on our end. If others are interested in this feature, please upvote the comment to help us prioritize it!
@pwied and @thorsten.langner , We’re currently implementing field comparison within a condition. I’ll update this thread once the next iteration is released!
Thank you for the feedback @thorsten.langner, I am glad you liked the feature
We’ll further develop this incrementally, and having these feedback is very valuable for the next iterations. Please keep updating the thread when you have more ![]()
I went ahead and moved @jjj request into a separate product suggestion thread, so anyone interested in bringing conditional formatting to analytics should go ahead and vote on it there!
I think “input is exited” trigger does not resolve these request. (I tested the trigger in my sandbox instance)
Those requests are asking to make a trigger when input changes.
“input is exited” is triggered only when the input is exited.
Hi @ta-aoki
on one hand I agree, on the other hand I see the risk of an actual input change trigger.
You could easily set a more complex filter (e.g. full text search), that is calculated on the database. Therefore you must reload the whole table by a connector function.
Imagine you would build this and type 25 characters.
This ends up in 25 connector calls and processing the data afterwards in tulip.
Or you set this data to load a record, change a record and clear it again. Then you write a whole message of 100+ characters.
This would force the trigger to run 100+ times.
there are possible solutions (e.g. loading after 300ms after the last change or so) but then someone would wonder why its not pushing every single character to an arras or whatever…
I simply want to say: It’s not that simple and might cause some other issues…
