Hiding badge ID
Is there an option to hide the badge ID when logging into the player or using the signature widget. We do training in a group setting and showing the trainer’s badge ID on the large screen for everyone to see is not desirable. We can do a workaround and create a training user account as a dummy user and avoid using the trainer’s own badge ID during the training session but still the ID is now known to everyone in the session.
Hi @Attaboy
it’s actually the first point on this list (if it comes to login)…
[Tip of the Week] Defining Player Settings - General - Tulip Community
I’m not sure if it also effects the signature widget.
However, if you run into a situation, where you cant hide the Badge ID, you could create a complex one (a long randomstring) and copy paste it into the input. This will at least reduce the chance of someone picking it up…
Excellent tips as always @thorsten.langner!
I’ll also add that every Tulip instance comes with a built in fake user “John Smith” with badge ID 0000. Another option would be to use John Smith as your example profile for trainings :slight_smile:
