I have some question regarding using API.
I’m relatively new to API and currently i’m trying out using tulip API and stuff.
I have found one of the post about how to use table API
https://support.tulip.co/docs/how-to-use-the-table-api
I was able to try using postman until create table id part.
but my question is how can I put the rest of the data into that id?
Let’s say i created ID how about the unique and number. How should I add them?
Need some help on this.
Thanks
