Installation to higher env
We have few dependent apps in Dev environments which are linked through App transitions. We are migrating these to higher env and noticed after migration some of the app transitions are showing as Deleted even though the dependent apps are present in higher env. We end up updating the triggers manually in the higher environment. What is the best way to avoid this issue? Another Question: How can we implement version control of the configurations and make sure the same configuration ( SHA value should be the same) goes to higher environment?
@kevin.kononenko : Could you please respond to this ASAP. This is a bit urgent requirement for us
When we do this, to preserve the navigation links, we need to import all the related apps in a group as one package.
Hi @jmlowden We have few reusable apps which are located in different folders and can’t move these to another folder. Can you please suggest how can we import all the related app in a group as one single package in this scenario?
Hello Madhab, we are aware that this is a challenge in the platform today. We want to solve it in the near future, but I do not have a specific date for you yet.
