We’re excited to announce the most recent release of the Tulip Library!
The Library is a set of apps, app suites, and connectors, that can be added to your account and used out of the box. Each app comes with an installation guide and a video describing how the app works, and what the app can be used for.
If you’d like to use any of these apps, click on the app’s link below and install it to your account today!
Release 35:
Flexible BOM with Work Instructions
The Flexible BOM with Work Instructions App Suite is a collection of Tulip apps that provides an adjustable bill of materials with integrated simple work instructions to guide operators through an assembly. Work orders can be scanned with a barcode scanner, or selected from a list. As a supervisor, view and add to the bill of process or materials. Operators will be alerted to new work orders and guided through simple work instructions from a template for each BOM.
Tulip Design Guidelines for RealWear Headset
The RealWear Headset Design Guidelines app provides examples and guidance for building apps that can run on RealWear wearable headsets. Support for the RealWear HMT-1 can be enabled by Tulip, and operators can use and interact with apps hands-free. Learn about how to navigate, interact with, and position components in Tulip apps designed for RealWear. Auto-advance work instructions, scan barcodes, add IIoT integrations, and capture quality data hands with intuitive voice commands.
Learn more in the Getting Started with Tulip on RealWear headsets support article.
Updates
In addition, two apps have been updated this release: Kanban System and Inventory Management received updated UIs.
