Library Release 75 - April 22
We’re excited to announce the most recent release of the Tulip Library.
The Library is a set of apps, app suites, connectors and widgets that can be added to your account and used out of the box. Each app comes with an installation guide and a video describing how the app works, and what the app can be used for.
If you’d like to use any of these apps, click on the app’s link below and install it to your account today!
Release 75:
TLDR: Library Release - r75
Video content:
eDHR Example
Learn how you can equip your assembly station with Tulip to collect information required for an electronic device history record (eDHR). Augment your operators with pick-to-light systems to error-proof assembly, integrate with scales to automate data capture, and ensure compliance with 21 CFR Part 11 and Annex 11 compliant eSignatures. With a faster way to collect and review data, you will be able to increase productivity, while reducing the risk of non-compliance.
Stations API Tutorial
The Stations API streamlines creating, managing, and deploying stations. With Stations API, your external systems will be able to transact and query data inside Tulip without the use of connectors. This tutorial provides a high-level overview of how to get started.
Apps:
Maintenance Order Request
The Maintenance Order Request app allows end users to submit maintenance tickets by selecting from a list of equipment and adding information. They are prompted to specify whether it is proactive, reactive, or emergency to help others assess urgency and prioritize requests. The single step can be copied into other production apps and all tickets are logged in a centralized table.
Maintenance Order Execution
The Maintenance Order Execution app provides maintenance technicians with an easy way to review and execute open work orders. Streamlining the process will help decrease unplanned downtime and increase uptime. When work orders are complete, the app provides maintenance managers with a digital trail to increase production visibility and traceability.
Maintenance Order Management
The Maintenance Order Management app helps maintenance managers stay organized with a centralized place to manage work orders and review equipment records. With just a glance at the dashboard in the Maintenance Order Management app, managers will be able to assess the health of their maintenance operations.
LabVantage Unit Test
The LabVantage Unit Test can be used to test connector integration from Tulip to the LabVantage LIMS solution. LabVantage helps you automate tasks and turn data into valuable insights. This unit test walks through confirming the integration is connected properly to get full value from LabVantage to Tulip.
Andon Management - Composable
The Andon Management application helps managers monitor station statuses in real time. This application allows managers to see a high-level view of open Andon and alert events to manage process issues and escalations across the factory floor. The Andon Management App works together with the rest of the apps in the Production Management App Suite.
Andon Terminal - Composable
The Andon Terminal app provides management for andon and alert events throughout the shopfloor. Users can create and execute orders for alerts in real-time, making escalations quicker and simpler.
Machine Monitoring Terminal - Composable
The Machine Monitoring Terminal app is designed for operators and supervisors to track machine utilization and performance. Operators can add notes and context to downtime reports, and log production rates and parts produced per hour. The Machine Monitoring Terminal works together with the rest of the apps in the Production Management App Suite.
Performance Visibility Terminal - Composable
The Performance Visibility Terminal app facilitates the collection of granular, real-time data from the operations floor to better understand performance. Designed to stay at a given station or machine, the app prompts operators to choose from a list of orders and report the number of good parts produced for that order as well as defects. The operator can change the status of the station or machine and include a reason when the status is changed to down. The analytics dashboard displays real-time key metrics for that station, including downtime and update, first pass yield, as well a Pareto chart for downtime reasons and a historical view of the station status. This app is part of the Production Management app suite.
Performance Visibility Dashboard - Composable
The Performance Visibility Dashboard is used to display key metrics and charts useful for understanding how well production is performing. Maximize uptime with an uptime percentage metric, a downtime reason Pareto chart, and running time for each station. Understand performance at a glance with First-Pass Yield, station statuses, and daily status distribution. This app is part of the Production Management App Suite, and built on Tulip’s common data model.
Operations Management Dashboard - Composable
The Operations Management Dashboard provides greater visibility into key operational metrics including safety, performance, quality, and availability. With real-time visibility into these metrics, you will be able to make informed decisions to improve operations and employ continuous improvement methodologies. The Operations Management Dashboard works together with the rest of the apps in the Production Management App Suite.
Order Management - Composable
The Order Manager app allows you to quickly create and dispatch orders into production. Within the app, you can view BOM requirements and select available lots. This app can work with other apps in the Composable MES App Suite. You can extend and configure the app to dispatch orders from a table, or from an external ERP system. Configure it to match your operations. The Order Management App works together with the rest of the apps in the Production Management App Suite.
Order Execution - Composable
The Order Execution app guides operators through selecting an order, completing the order with visual instructions, and then logging the completed quantity. After the order is fully executed, the operator can then confirm completion and print a label. The Order Execution App works together with the rest of the apps in the Production Management App Suite.
Review and Ship - Composable
The Review and Ship app allows you to process the review and approve the shipment of final products. This app provides visibility into work order details and management of shipping details, like final reviewal and label processing. The Review and Ship App works together with the rest of the apps in the Production Management App Suite.
Quality Management Dashboard - Composable
The Quality Management Dashboard provides visualized analytics for examining specific factors of your manufacturing process. The dashboard simplifies tracking quality trends for products, batches, and defects. The Quality Management Dashboard works together with the rest of the apps in the Quality App Suite.
Quality Inspection Template - Composable
The Quality Inspection Template provides a starting point for creating a quality inspection app to guide operators through a series of inspection steps and log identified deviations. The template includes options for a full inspection of one unit and sampling a batch of units. The Quality Inspection Template app is part of the Quality App Suite.
Defect Management - Composable
The Defect Management App provides a tool for determining and logging the next steps for defects in a process. The app enables users to manage defects by allowing users to log defect events, edit defect status, disposition and provide rework details when necessary. The Defect Management app is a part of the Quality app suite.
Inventory Management - Composable
The Inventory Management app provides an inventory management table structure to support the collection of inventory data. The table includes parameters such as Item, Location, Status, Serial, and Quantity. Items stored in the table can be called upon and moved or adjusted to streamline the digital tracking of your inventory. This app works together with the other apps in the Inventory App Suite.
Inventory Dashboard - Composable
The Inventory Dashboard displays key metrics and charts about inventory throughout your facility. It provides visibility into your inventory, including inventory levels, quantities, and locations. The Inventory Dashboard works together with the rest of the apps in the Inventory App Suite.
Material Loading and Receiving - Composable
The Material Loading and Receiving app guides users through the process of documenting the arrival of new materials, including truck ID, company, gate ID, shipment type, and a photo of the materials before unloading them. After confirming the unloading is complete, they are prompted to capture an image to provide proof. The Material Loading and Receiving app is part of the Inventory App Suite.
Material Warehouse - Composable
The Material Warehouse App allows you to manage and track transacting material to a warehouse. This can provide streamlined management and visibility of material storage in your warehouse. The Material Warehouse App works together with the rest of the apps in the Inventory App Suite.
Apps Suites
Composable MES App Suite - Composable
The Composable MES App Suite provides a starting point for your frontline engineers to create innovative production systems that can leverage Tulip’s AI, analytics, vision, and edge connectivity capabilities to meet your exact needs on the shop floor. These apps are easily configurable building blocks designed with manufacturing best practices to accelerate time to
Production Management App Suite - Composable
The Production Management App Suite provides real-time visualization of what is happening in production – at a station, machine, cell, and/or site level – and relevant insights to improve operations. The included apps offer visibility into production by monitoring assembly, machines, and processes throughout the production floor. Increase productivity with real-time alerts and performance analyses to resolve issues quickly and prioritize improvements that streamline operations. Built off the Common Data Model, the Production Management App Suite is interconnected with other apps in the Composable MES App Suite and easily extensible to meet the specific needs of your operations.
Quality App Suite - Composable
The Quality App Suite supports activities to reduce the occurrence of quality escapes and reduce the cost to mitigate quality issues, such as rework, scrap, and root cause analysis. The included apps help you error-proof your workflows by increasing the efficiency and frequency of quality checks. Built off the Common Data Model, the Quality App Suite is interconnected with other apps in the Composable MES App Suite and easily extensible to meet the specific needs of your operations.
Inventory App Suite - Composable
The Inventory App Suite supports activities for ensuring accurate warehousing information and preventing unexpected material shortages. The included apps provide real-time status of inventory levels to improve material flow visibility. Built off the Common Data Model, the Inventory App Suite is interconnected with other apps in the Composable MES App Suite and easily extensible to meet the specific needs of your operations.
CMMS App Suite
The CMMS App Suite is a collection of 3 apps that help you manage and schedule maintenance across your facility. The apps can be easily configured and centralize your data and maintenance information, enabling supervisors to dispatch work orders efficiently. Operators can report faults or issues as they arise, and technicians can monitor open maintenance orders, and view performance metrics on historical data from completed work orders.
eDHR App Suite
The eDHR App suite provides a fast way to build your first electronic device history record app and review it accordingly. With an electronic device history record process and review app, you can streamline operations, collect critical production data, and ensure compliance, with accurate review processes. This app suite provides templates for both processing and reviewing apps.
Connector
Inkit Connector
The Inkit Connector facilitates easy connectivity between Tulip and Inkit for sending templates to printers. The Inkit Connector providers templates to simplify printing. Inkit and Tulip partner to provide an intuitive solution to printing forms, documents, and more from your Tulip apps.
MRPeasy Connector
The MRPeasy Connector enables you to connect Tulip to MRPeasy and transact data between the two systems. MRPeasy is a material requirements planning (MRP) software that helps manufacturers be more organized.
eLabNext Connector
The eLabNext Connector enables you to integrate Tulip with eLabNext. eLabNext is a lab management software that helps track samples, submit experimental entries, and manage SOPs. This connector leverages Tulip’s user-friendly interface and eLabNext’s lab-focused solution to increase traceability and ensure compliance.
Veeva Connector
The Veeva Connector streamlines connectivity between Tulip apps and Veeva. Veeva is a provider of cloud-based software solutions for operating challenges and regulatory requirements in the Life Sciences & Consumer Products industries. Paired with Veeva, Tulip can act as a front end for your Veeva solutions to provide a human-centric interface for leveraging Veeva’s solutions.
Oracle Fusion Cloud Connector
The Oracle Fusion Cloud Connector allows you to connect your Tulip apps and automations to Oracle Fusion Cloud applications to get inventory data, maintenance and work order information, and create production reports. This integration contains several functions that can be adapted and configured to meet the needs of your specific Oracle Fusion Cloud implementation.
Augury Connector
The Augury Connector streamlines the connection between your Tulip apps and Augury. Augury is a predictive monitoring solution that can pair with Tulip to enhance your predictive maintenance experience. Partnered, Augury and Tulip can help you solve use cases like condition monitoring, predictive maintenance, and more.
LabVantage Connector
The LabVantage Connector allows you to integrate with LabVantage to streamline data transfer in your lab. Using LabVantage with Tulip provides you with an easy way to collect data from the frontlines, giving you greater traceability and visibility to make better decisions and accelerate the research process.
Widgets
Kanban Task Management Widget
The Kanban Task Management Widget provides a custom widget for managing an interactive Kanban board. The widget allows you to add task or order card to status columns. Cards can be dragged and dropped between columns, like a traditional Kanban or Scrum Board. Custom Widgets are additional functionality that is not standard in the platform. Widget plugins are accessible in the app editor menu bar.
Badge Widget
The Badge Widget provides a simple, intuitive to create a badge notifications for supervisors and managers. The widget allows real-time notification for Tulip apps. Widget plugins provide additional functionality that is not standard in the platform. Widget plugins are accessible in the app editor menu bar.
Progress Bar Widget
The Progress Bar Widget provides a simple loading bar for easy progression tracking. The widget can be used to visualization for work instructions, looping, analytics, and more. Widget plugins provide additional functionality that is not standard in the platform. Widget plugins are accessible in the app editor menu bar.
json Tree Viewer Widget
The JSON Tree Viewer Widget provides a custom widget for viewing JSON details within an app. The widget can display JSON as a tree format that is easy to explore and understand. This is helpful for debugging tasks or viewing a large set of nested details, where raw text may be difficult. Custom Widgets are additional functionality that is not standard in the platform. Widget plugins are accessible in the app editor menu bar.
