Library Release 31 - November 2021
We’re excited to announce the 31st release of the Tulip Library!
If you’d like to use this app, click on the app’s link below and install it to your account today!
Release 31:
CMMS App Suite
The CMMS app suite is a configurable solution for managing and scheduling maintenance on equipment in your operation. Computerized Maintenance Management Systems (CMMS) centralize maintenance information and enable supervisors to dispatch work orders to operators. Add work instructions to guide operators through maintenance procedures. Manage parts inventory lists needed for each type of routine maintenance. Allow operators to report faults or issues as they arise, and dispatch work orders to address them. Monitor open maintenance work orders, and view performance metrics on historical data from completed work orders. This app can be configured with other solutions such as an ERP connector, to meet the needs of your operation.
