We’re excited to announce the latest release of the Tulip Library!
The Library is a set of apps, app suites, widgets, and connectors, that can be added to your account and used out of the box. Each app comes with an installation guide and a video describing how the app works and what it can be used for.
If you’d like to use any of this content, click on the link below and install it to your account today!
Apps
Template for Work Instructions
Use this app to create work instructions apps quickly, with different layouts and step templates. Copy layouts to build new work instructions faster, and configure each template to your needs.
Updates to apps:
The Static Work Instructions app has been updated to include translated versions in German and Spanish in addition to English. Tulip apps support multilingual translations, making it easier to deploy apps in different facilities and support users in their native language.
*Multilingual Translations are an Enterprise feature. Please contact support@tulip.co with any questions.
The Tulip UI Template has received a refresh to give more canvas space and utilize the updated button with the icon widget.
Widgets
Widgets are the latest plugin content available in the library. Available through unit test apps in the Library, Widgets are additional functionality that is not standard in the platform. Once downloaded from the Library, Widget plugins are accessible in the app editor menu bar. Widgets can be edited with a low-code interface in the app editor.
Work Instructions Care Points Widget
Add visual indicator banners to inform operators of important information. Choose from four banner types designed to indicate EHS, Quality, Best Practices, and Hazards.
Number Pad Widget
Quickly enter numerical data into an app with a graphical number pad.
Calculator Widget
Add a graphical calculator to apps for quick calculations.
Change Detector Widget
Detect when a value has changed and provide a visual alert to an operator.
Stopwatch and Timer Widgets
Track time within an app with simple interfaces that can count up or down based on a set time.
Looper Widget
The Looper Widget can loop through a list of actions in an application. Define a list of items and events and the widget will run a trigger for each item on the list. As the loop runs, a visual indicator will show the progress of the loop.
Five previously released widgets have been updated to include new descriptions and set up instructions inline. ZPL Viewer, Tool Tip, Step by Step Menu, Custom Text Input, and Custom Number Input widget. If you are already using these widgets, you will need to re-install them through the custom widgets interface to use the latest version. See all widgets in the Library →
