Machine Page Widget Customization
Having the machines page is a nice way to visualize machine state as a dashboard without creating an app. However there little customization to the machine widget the way the you can in an app. it can only display machine attributes in the order they are made in the machine type setup. raw data is OK… machine activity fields is better. Number 1 thing that would be most useful to have on these would be the real-time machine uptime, like in the machine timeline. This is coming from an aerospace manufacturer, where machine uptime is naturally critical to operations.
Hello @Blake237,
Welcome to the community, and thank you for your suggestion!
If you navigate to the “Machine Timeline” widget, you’ll find a toggle in the context pane labeled “Show Machine Uptime.” Would that meet your needs, or are you specifically looking to display machine uptime directly within the Machine Status widget?
Best,
Cana
Specifically in the machine status widget, plus being able to easily change the ordering of what is displayed in said widget.
