Mask data entry
All,
We have a use case where we will need users to enter their password for an internal system that we use a connector to access. We would need to mask the input for obvious security reasons. I have found a few threads on this topic and was wondering if any progress is being made.
A password acting field
Entering Hidden Password on App
Can we have input box as password field?
Hidden Text Input Widget
@Pete_Hartnett is your custom widget (Hidden Text Input Widget) still the only solution to this password text input widget product suggestion? Other than putting a block in front of the input widget. I’m running the r323.1 (June 2025) version. The HTML password input field was first created in HTML 2.0 (1995).
