Can I, somehow, use an input box as a password field, meaning, if the user enter data into it, it will appear on screen with ***** instead of the data itself
we have even tried for signature form but it is showing only username and not password.
hello @suvarnap, thanks for posting!!
have you considered using LDAP on your Tulip instance?? if you enable it, users will be required to sign in with their credentials: Creating A Signature Form Step | Tulip Help Center - Support for Building Manufacturing Apps.
let me know if you have any questions!!
