Hi, I am interested by the answer of this topic also. What is the max length of a text field in table ?
Continuing the discussion from Max Characters in Text Field:
Hi @Fiora,
in UTF-8 each character has 1 - 4 Byte.
That means, in a table field there is space for 640 to 2560 characters. (2,5kB * 1024B/kB = 2560B)
The fierst 128 characters use 1 Byte each. That means standard Latin character text with the most common symbols ! " # $ % & ' ( ) * + , - . / : ; < = > ? @ [ \ ] ^ _ { | } ~ and 0-9 can reach up to 2560 characters in a table or up to 51200 characters in other cases…
Edith:
@John did I do the math wrong? I managed to save exactly 50000 characters in a Table field, which is eqivalant to ~48.8 Kilobytes
I would count that as 50kB but way more than 2.5kB
Hey all,
While there is some technical size limit, I want to flag that there might be another question worth answering here.
Could you share what you might be storing into a field that could potentially reach somewhere near either of these limits? If this much data is needed in one table field, it may be worth taking a look into how data is being stored more generally in these tables, and if there is a more appropriate table architecture that could be utilized to maximize efficiency / reduce size concerns.
Brian
In my case I don’t have any use cases yet, but I think its good to know the limits.
One use case, could be to save a JSON file, to put an object array in a table.
As long as you need do loop through a table to save and get an object array this might be a workaround.
For instance, I have a measurement result with x an y values for a line chart.
I have it like this:
[{"xValue":1,"yValue":0},{"xValue":2,"yValue":-1.8},{"xValue":3,"yValue":0.5},...]
I do have those values beside a whole bunch of other values in a table, but I neet to loop through it to get an object array for usig it in app.
So saving this as an extra value in a measurements table could be a use case for long strings.
As mentioned, this is just a workaround!
@Brian_Haselton
We store measurement data in Tulip Table as text type. We do extract some typical data from it and store it in the Number type field, but it is important for us also to store the raw data for traceability.
We are also planning to put our original pseudo-SVG type data to be used in the custom widgets.
@John Please let us know why we can import 50000 characters in Tulip table text type although the KB article say 2.5KB is the limit.
FYI, when I tried 50001 characters, I got this error.
@Brian_Haselton We also have some use case to store list data joined to single text in text type field such like “‘aaa’,‘bbb’,‘ccc’”, and search record with the query contains ‘aaa’.
