Max lenght of input
Hello Friends, small question, is there a function that can maximise an input whether text or number?
example, the maximum input of the ID is 10 values and more than 10 is not entered.
Hi @akramyahwar
there is no existing function, but you can use the custom widget “Change detector”
Check the length of the input variable and cut the variable (left-function) if the input length is more than the preset input length.
It works, but sometimes when I type quickly, it needs one more input to recognize the change.
Regards Chris
I don’t get what exactly you mean.
An input widget? A variable itself? A Table record?
Where is a limit of 10? could you provide an example or a screenshot?
ahh thanks for your message:) i will try
only an input, i mean if u build an input text or number but lets say the max input should be 10 or 5 or 20. But i know now existing function. I got a message from the tulip support and they told me.
This sounds like a great custom widget for anyone so inclined :wink:
@william_vanbuskirk for vis
oh, and @akramyahwar et al, input validation is something that our design team is actively working on, so more soon here in the next few months.
ahh nice to know, thx for the information
