Metadata defaults
If this feature is available, I have not been able to find it, but I would like the option to be able to toggle on table meta data by default or the ability to save a custom view within a table where I can turn meta data on. I find myself needing to look at records for more recent events a lot and have to go and turn on and sort the meta data fields every time I open the table.
Thanks!
I asked for that a few years ago. Maybe soon….
I second this! Very annoying.
Thank you all! This has been fixed with r340.
