Mobile Player 2.4.0 Release
Version 2.4.0 of Tulip Mobile Player will be available for download by 9:00 PM ET on September 13th, 2024! If you have auto-updates enabled, the Mobile Player application will update in the background and changes will take effect the next time the application is restarted. Alternatively, you can manually initiate the update process from the menu.
Hi Jake,
Is there any chance this update fixes the problem that pdf files are not previewed inside the app but downloaded to the device instead? :smiley:
Thanks!
Alin
Which menu are you talking about? I do not see the update button in my current mobile player.
Will it appear after the update is released ?
I do see the menu on the desktop player.
Hi @alin.sala,
I don’t believe that issue has been fixed within this release.
Sincerely,
Jake
Dear @ta-aoki,
The manual update would be managed through Apple’s App Store, not on the Tulip Mobile Player itself. Please see this support article from Apple here.
Hope that clears up the confusion!
Sincerely,
Jake
I updated the player but the table with non-ascii character ID still does not seem to export. Does our server need to be updated to specific version?
https://support.tulip.co/docs/factory-286-release-august-2024
r286 seems to be the one we need. thank you for the fix!
could you share me the download link of the latest Tulip player for Android
Hi @Xin -
You can find the latest player download links here: https://download.tulip.co/
Thank you anyway.
But there is no direct download link of the latest Tulip player for android. Because I have no access to the Google play store to download it
Ah I understand @Xin - here is a link you can download Player for android directly from https://download.tulip.co/releases/android/prod/Tulip%20Player.apk
Thank you. I have got it
