Hi all,
Does anyone have already adress a MPS (Manufacturing Planning and Scheduling) use case with TULIP ?
Or does TULIP have a partner that can do that ?
Best regards,
Paul
Hi all,
Best regards,
Paul
Some of our internal customers use https://www.oplit.com/ in combination with Tulip (and ERP). I believe the https://planeus-solutions.com/ solution is a partner in the Tulip ecosystem. https://skyplanner.ai/ which I’m not familiar with, seems to be coming up a lot at the moment.
Hi Youri,
Thank you very much for your feedback. I will look into these tools!
Paul
Hey @paul.genoud ,
Sunny from planeus here, yes we do MPS, and not only we’re a Tulip partner, we have an established connector with Tulip! ![]()
Let me know if you are interested in a quick call and we can show you how our MPS work with Tulip!
Sunny @ planeus
