OneLogin SSO and SCIM setup
Has anyone Successfully setup Onelogin SSO with SCIM using Tulip?
You can set up OneLogin with Tulip, but a couple things have to be in place first. Tulip only enables SCIM after SAML SSO is configured, so you’ll want to get SAML working in Tulip before adding the SCIM side in OneLogin. Once SAML is active, Tulip gives you the SCIM Base URL and Bearer Token you’ll need for the OneLogin “SCIM Provisioner with SAML (SCIM v2)” app. Tulip’s SCIM supports creating users, updating names, and deactivating users.
If you’re running into a snag with provisioning tests or attribute mappings, feel free to share the part that’s blocking you and I can do my best to point you in the right direction.
Nicolo,
Great feedback and thank you. Recently learned that 14.8 does not support SCIM, but 15 does. I will follow up, thanks again.
