Output to Google Drive
Hoping to have Tulip Output’s connect directly to a Google Drive document. Do not need to be able to edit data, just need the form output put into a Google Drive document.
Could not find the answer here: Google Drive Connector | Tulip Knowledge Base - Support for Building Operations Apps
Thanks for your help!
Hi @ghohbach. We’ve done a lot of the hard work for this already with our library connector and unit test. That said, getting this set up will benefit from some understanding of APIs and OAuth. Let me know if this is something you need additional context for and I can add getting these connectors set up to the University course backlog.
