Since Tulip can connect to anything with an API and Microsoft 365 allows API connections… Tulip and Microsoft can be best friends.
If you don’t know how APIs work or how to deal with authentication… you aren’t alone. I also have basically no idea what is going on with these things. Anyway, I documented the process of setting this thing up for whoever needs it. Not shown is the hour or so I spent trying to figure it out. Hopefully it should only take you a few minutes if you follow the video, below.
Here is a video that shows exactly how to connect excel 365 to Tulip using the connector from the library.
