Pending approvals for published apps
even though there is already an option to see the apps which I have to review I would like an option to see the which of my released apps need to be approved. Currently, its tough to keep track of my apps since I’m not responsible for only one app and it occurs frequently that 3 or 4 app versions get stuck in the review process and I have to find out which app is stuck and who I have to ask for review.
Kind Regards,
Oliver
Hi @OliverGnepper thanks for the suggestion. Just so I understand your request, are you asking for a list of apps that you’ve submitted for publishing that are still awaiting approval?
If this is correct, what would you expect to do after you see this list of apps pending approval?
Hi @shep,
yes that is pretty much what I was asking for.
I would ask the person in charge to have a look at my app. Usually the notification mails get lost among the bunch of other mails. The requested list is just a little helper for me to track my apps that await approval.
Kind Regards,
Oliver.
Hi, I’d like to add that it would be great not only to see the apps pending approval as a developer but also to have access to all apps with pending approvals in general, not just mine or the ones I submit for publication. Since we have more than 250 apps published, it can sometimes be hard to track all of them
This feature would be incredible! I typically have to go back through apps to verify if all approvals were received and if not send email reminders. I likely forget to check some apps leading to outdated apps in production being used far longer than they should be.
At least now I can tell them to go check their Pending Approvals list while they are already logged in to see if there are other apps waiting for their review that I forgot about.
Most important for me would be the ability for me to see the status of all apps that I submitted for approval.
Secondary would be the ability for a workspace admin to see the status of all (not archived) apps in the workspace.
I agree with the above comments. Similar to the “pending approvals” section, it would be beneficial to have a dedicated area to view apps that are currently awaiting approval. This would provide a convenient way to monitor the status of apps I have published or that other team members have published under review.
Adding to @emendoza’s comment, it would be helpful to have a complete view of all pending approvals. This is especially important in cases where a colleague is on PTO, leaves the company, or is otherwise unavailable, ensuring that approvals are not delayed.
