mcombs
1
Hey,
I saw this post about using a regex in the output field of a connector:
Is there a way to use JQuery manipulation in the connector output fields?
What I am looking to do is convert a string saved into a table to JSON format and then output a specific field there. Would that be possible?
thanks
-Matt
Beth
3
Hi Matt,
Perhaps would this post help you with this question? Storing Objects in Tables and Extracting from JSON Strings
