Exciting news - Release 355 is here!
Share your thoughts and questions below
Toast messages will now automatically dismiss after 10 seconds.
What was the old behavior for this change?
Hey @ta-aoki -
Previously, toast messages (those little popups in the top right corner) would never automatically dismiss. Now these will automatically dismiss after 10 seconds.
Hope this helps -
Finally ![]()
I appreciate this!
Hi Pete.
Would you mind also shedding some light on this for us? I have trouble understanding how things works between the past no-dismiss, the present 10 second dismiss and these two settings.
Is the release note referring to toasts displayed in Tulip’s web browser interface (when building apps, working with tables, with connectors etc.)? (I can exactly recall what these look like.) Whereas the settings I screenshot refer to these yellow and red toast messages displayed at the bottom of the player?
I meant can’t ![]()
Hey @fti -
You are right, the settings in your account settings only impact message show to operator in the Tulip Player. This change was exclusive to the web editor for things like the tables pages, connector editor, etc.
