Player 2.10.1 Release - February 2026
Version 2.10.1 of Desktop Player will be available as of Feb 14th, 2026 at 9 PM!
Key Points:
  • A camera-switching bug has been fixed.
  1. If you have auto-updates enabled, the Desktop Player application will update in the background and changes will take effect the next time the application is restarted. Alternatively, you can manually initiate the update process from the file menu.
