Version 2.10 of Desktop Player is available for download on 9:00PM ET (Jan 31st, 2026)! If you have auto-updates enabled the Desktop Player application will update in the background and changes will take effect the next time the application is restarted. Alternatively, you can manually initiate the update process from the file menu.
Key Points:
- A Cognex Insight run command fix.
- A SAML-related bug fix for SAML login on Player.
