Hey Crew -
Version 2.11.0 of Desktop Player is available for download at 9:00PM ET Tomorrow (June 13th, 2026)! If you have auto updates enabled, the Desktop Player application will update in the background and changes will take effect the next time the application is restarted. Alternatively, you can manually initiate the update process from the file menu.
Hi @Pete_Hartnett ,
thanks for updating.
With
- Upgraded the player runtime, bringing performance and security improvements to the Desktop Player.
Do you also mean the opening performance? Unfortunately I can’t confirm, while @Nicolas can
→ Tulip player - opening performance - Support, Troubleshooting, & Help - Tulip Community
Or is this a separate topic?
Edit:
It seems to be different.
Now it is like half the duration (10s not 20s).
I will keep an eye on that the next days
