Version 2.10.2 of Desktop Player will be available as of Feb 21st, 2026 at 9 PM!
Key Points:
Prevents an issue for printing document widgets with a file variable.
torqueOP and multi-torqueOP will not automatically subscribe to alarm events and this functionality has been feature flagged.
- If you have auto-updates enabled, the Desktop Player application will update in the background and changes will take effect the next time the application is restarted. Alternatively, you can manually initiate the update process from the file menu.
