Version 2.7.1 of Desktop Player will be available as of January 18th, 2025 at 9 PM!
There’s a bug fix related to printing and custom widgets.
If you have auto-updates enabled, the Desktop Player application will update in the background and changes will take effect the next time the application is restarted. Alternatively, you can manually initiate the update process from the file menu.
