These are the product updates in release 172.
Release 172 goes live to all “production” customers on 10/27/19.
Product Changes
Upgrade to HTTP and SQL Connectors
- Visual improvements for both HTTP and SQL connectors
- Test HTTP connectors with one click. No need to test them in apps.
- Point and click to define which data to store in “Outputs”
New Styling Options for Buttons, Images
- Add a drop shadow and border radius to buttons and images
Edit Multiple Widgets At Once
- If you click and drag to select multiple elements, you can now edit properties like font style and background color
New Knowledge Base Articles
How To Add a Grid Widget to A Step
How To Add a Gauge Widget To Your Step
How To Calculate First Pass Yield with a “Number” Analysis
How To Create a Pareto Chart of Common Defects
How To View Cycle Time Statistics by User with a “Table” Analysis
How To Analyze Quality Inspection Checklists with a “Multiple Variables” Analysis
How To Compare Defects by Type and by Day using the “Compare By” Field
