Release 226 - April 2022
Release 226 is live! Read below for some of the highlights.
:tada: Plugins are now available!
  • Read the official announcement here!
With custom widgets, you can build completely customizable drag-and-drop elements for your operation using HTML, CSS, and Javascript.
:zap: Connectors
  • The connector functions page now shows which apps use the function and allow the user to navigate directly to the apps
  • Users can now perform a full text search on connector functions
  • On the connectors overview page, connectors can be filtered by type (HTTP/SQL)
:iphone: App Editor
  • When creating a new app, users can now choose to build apps directly from the library or to build from scratch.
  • Users can add a custom footer to the bottom of each page of a printed record history. The footer can be static or dynamic.
  • Allow multi select scaling (resizing)and rotating of widgets in app editor
  • Adds a trigger action to copy a provided string to the clipboard.
:bar_chart: Analytics
  • Added support for timescale representation of datetime values on the x-axis in One Operation chart
:lady_beetle: Fixes
  • Fix issue around drag-and-drop with triggers
Woah! Custom widgets! Very exciting stuff
