Hey All!
Wanted to share a quick integration I did today. As many of you know, texts can be sent from Tulip apps, but if you are running into a limitation with the SMS functionality of triggers, Twilio might be the right option.
Twilio, for a cost, hosts API endpoints that can be used to send text messages to any phone number, check out this video where I walk through the setup and integration process.
Hope this helps!
