In automation, when I want to set an object variable with an other object variable, I can’t.
I have to link object fields 1 by 1 even if objects are perfectly similar
Thanks Thomas,
We’re adding this to our list to triage, and will follow up if we’re able to fit it in as a smaller project.
In the meantime - others on the Community please feel free to upvote. We take upvotes into consideration when prioritizing feature enhancements and especially efficiency improvements.
One metric we’re considering using to aid prioritization:
How much time do you estimate this improvement would save your team?
- Olga
About the saving time, I think it could be something like 2min per variables we want to set.
But it’s not the sole metric. We can also save lot of serenity. It’s much more esier to link 1 variable instead of 5. In term of debugging, we can save 5min in my opinion.
Thomas
