Hi Team,
I have a barcode containing three concatenated values without a separator. I need to split the different values and place them in the corresponding fields.
The barcode length is always the same, and all the values have the same length.
Example:
Barcode to scan: WOXX1G20950
Field 1: WOXX1
Field 2: G209
Field 3: 50
Which function do I have to use since I can’t use the “split” due to the absence of a separator ?
Much appreciated!
BR,
Safouane
