Target Lines, Trend Lines, Pareto Lines on same analytic
The ability to mix and match line types in the same analytic would be very helpful. A pareto with a target line, a bar graph with a trend line and a target line, etc.
Hi @zacharia.hicks thanks for the suggestion. Curious, where do you intend to use these charts and with what goal?
If there are others in the community that want to see this feature added, please upvote or post your use case here!
It has been requested by multiple people in leadership where I work, to have the trend line and the goal line in multiple analytics. As well as goal lines in Paratos. We tend to fit a lot of analytics in each of our steps because we are using a very wide variety of data points. Using combining analytic features would allow us to lower the amount of analytics on a step and free up space to display other information.
@zacharia.hicks understood, thanks for the additional context! We will track this request on our end and see what we can do.
Hi @shep is this functionality available?
I want display the target value based on the date range selected by the user.
In my case for example: Every hour operator can assembly 10 units, If the user selects the date range of 24 hours, In the analytics for the selected range I would like to convert into hours and multiply it by 10. So that the Target value varies based on the selected range.
I am able display the actual values, but not able to display the target value.
In the analytics I want to display Target VS Actual for the selected date/time range.
Is this possible to achieve using the Analytics?
Shrinivas
Hi @Shrinivas.Kandakur, we haven’t yet built this feature and made it available yet. Your additional ask for it though has been noted, and we will keep you updated with any progress on it. Thanks for posting your use case!
