Text to ASCII code
Hello
I didn’t see any topic talk about it.
Is there anything that I can do to convert Text (input) to Ascii code ?
Thanks for you help
Kinds Regards
FTR
You could make a table with all of the Ascii codes with their corresponding character as the ID and then loop through the input string checking if the character is in the table then return the code from the table.
HELLO
Thank you for your help.
Kind Regards
FTR
