Hey is there a way to make an application folder a sub folder of another folder? I know you can create subfolders, but I don’t know how you move them other than by transferring each application to a new folder created as a subfolder.
Go to the Apps Page and then on “Apps” in the Navigation Tree on the left.
Choose the top level Folder, you wont to become a sub folder (don’t open it) and klick the ... on the very right.
Choose Move and select the parent folder of your choice.
Hope that helps ![]()
Thanks for the quick response @thorsten.langner !
@Shrmnatr Here’s a video demo to support Thorsten’s description:
