I have large volume of images to be loaded into tables as these are part of instructions for operators. I’m taking here about 2000+ images per different plant. I was wondering if there is simple way I can upload CSV file with URLs to images stored on SharePoint and in background Tulip could fetch these images and save in S3? From what I tested images stored in local SP can be only displayed in Test mode but not Player itself, correct?
We talked with the Tulip support team about this to see if there was a solution we could provide, but we do not have any solutions currently for bulk image uploads. In the future, we will make a public facing endpoint with additional documentation so that you can upload images in bulk.
Thanks for raising this @Kris !
Any update on this? Have a similar use case for surgical kit inspection, bulk upload of product images.
