Use Copilot for Output Extractions in Connector Functions!
Hello Tulip Community!
We recently released a new tool that will help you build faster with connector functions. Here is how to use it:
  1. Once you are satisfied with your test response, simply click on the Copilot icon, and it would create outputs for you based on your payload. It won’t touch anything that you’ve built already.
  2. Refine/ Remove the output to your liking.
  3. Run the function again to add it into your output!
Copilot for connector output
Available with r348!
